how can i pait my atv??? HELP!!!!!
You can paint the plastic with most car paints on the market today. Stop at a body shop or your local car parts store that carries paint products, they should be able to set you up with what you need. You can not however, use the sealer that is usaully laid down before a proper paint job on a car, the reason being, that the sealer is not flexible like the base/clear coats are. It will crack and fall off quickly ant time the plastic gets tweeked a little. Just remember when painting anything, the work you put in to it will directly effect the outcome and how it will last and look!
