plug test?
Old Feb 8, 2004 | 12:58 PM
bansheeguy13's Avatar
Default plug test?
can some one tell me how to do the plug test so i can tune my carbs
Old Feb 8, 2004 | 01:05 PM
caliraptor's Avatar
Default plug test?
Get on ur quad, turn it on, do a wide open throttle run in 5th or 6th..I dont know how many gears a banshee has...and then just pull the clutch and kill it real quick...then just get off and look at your plugs!
Old Feb 8, 2004 | 01:11 PM
Default plug test?
what am i supposed to be looking for on the plugs what is it supposed be what does it look like if its runing to lean or to rich
Old Feb 8, 2004 | 01:14 PM
Izord's Avatar
Default plug test?
Look at this: http://www.dfn.com/benkaren/jetfaq.html
He talks about jetting and the "plug chop" test.
Old Feb 9, 2004 | 01:39 PM
Shav0's Avatar
Default plug test?
The plug should be a brown ish color. If it is real wet then you are running to rich (to much gas) if it is white then you are running to lean (not enough air) When you jet your bike start rich, and work from there
Old Feb 9, 2004 | 02:48 PM
caliraptor's Avatar
Default plug test?
Isnt it "if its white then you are running lean (TOO MUCH AIR)????
Old Feb 9, 2004 | 03:09 PM
Shav0's Avatar
Default plug test?
hah yea
thats what i ment
thanks
Old Feb 9, 2004 | 04:58 PM
Doctorturbo's Avatar
GOT BOOST!
Default plug test?
http://forums.atvconnection.com/mess...ighlight_key=y
Try this. Best decription I have ever read!!!!!!!!!!
slowgsxr97
Mar 18, 2022 03:40 AM
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Ripinandtearin
Dec 11, 2017 08:06 PM
Big bousse
Sep 26, 2015 10:42 AM
Captjay
Jul 23, 2015 12:33 PM
