Gearing is a god send!
Old Feb 24, 2004 | 04:37 AM
Kintama's Avatar
Default Gearing is a god send!
Do you have to pull links in order to put on a 12?
Old Feb 24, 2004 | 05:10 AM
XxDumontRaptorxX's Avatar
I run 12 44 and pull 4th really good up hills.
Old Feb 24, 2004 | 07:48 AM
Ward660R's Avatar
Originally posted by: sixsixT
Bigger in back is better IMO.
I know what you are talking about, but can you explain how that works to me? please[img]i/expressions/face-icon-small-happy.gif[/img]
Pretending that 1 tooth in the front is equal to 3 in the back, how is it that a 14/40 is better than a 13/37?
A Raptor with 14/40 gearring at 8,500RPM goes: 93.77
A Raptor with 13/37 gearring at 8,500RPM goes: 94.14
that should both be a 2.85 ratio
Old Feb 24, 2004 | 09:45 AM
CaptBags's Avatar
Ward 660 - you don't drop both at the same time. only one or, the other.
Old Feb 24, 2004 | 11:15 AM
  #15
sixsixT's Avatar
Did you figure those speeds mathamaticly? It seems you did because 13/37 is just a bit higher by .011.
The way I understand it is the smaller the sprocket and the tighter the radius the more the chain has to bend/work, taking away power.
Your chain and spockets usually last longer also if bigger.
Old Feb 24, 2004 | 12:02 PM
  #16
Ward660R's Avatar
The speeds came from a gearring calculator, but the ratio came from a sheet I have printed.
I understand what you are explaining. Thanks[img]i/expressions/face-icon-small-cool.gif[/img]
Old Feb 24, 2004 | 03:24 PM
  #17
RoostItUp's Avatar
There is a ratio chart on renthal's web page. Gearing Ratios
John Reed
Sep 9, 2015 03:46 AM
awer1968
Sep 8, 2015 11:02 AM
Elkaholic
Sep 6, 2015 02:44 PM
