need help fast.....
Old Feb 25, 2004 | 08:21 PM
HiFlyinRaptorRyder's Avatar
Default need help fast.....
miniblaster- yeah your right, I said wrong in my last post. Go up one.
Turtler- banshee's are extremely sensitive to jetting(i know this because I own one and have had to rejet it a few times already because of temperature changes). 4-strokes are not nearly as sensitive and hardly ever require a jetting change, unless there is an extreme change in elevation.
Old Feb 25, 2004 | 08:28 PM
miniblaster's Avatar
ok, so just go up one on the mains, and leave the rest alone?
that is the one thing i don;t understand, you have to change one jet, but the rest are ok to stay the same, isn;t that a little weird....
mini
Old Feb 25, 2004 | 08:54 PM
XxDumontRaptorxX's Avatar
Are you refering to not changing the pilot jets? You shouldnt ever have to change pilots unless you are really increasing the airflow. I have never jetted a banshee so i wont input on how to jet, but mains are the only ones you should change.
Old Feb 25, 2004 | 09:27 PM
maddog56's Avatar
the typical rule is that for every 20 degrees of change requires a change in jetting. That could mean as little as moving a clip on the needle or just a quick turn on the screw. It matters a lot whether you were jetted in the hot summer or in the spring/fall riding season. If you are very rich, then you wont need to change much with jetting when the temp drops.
TrickedToys
Apr 15, 2007 07:28 PM
TrickedToys
Apr 15, 2007 03:47 PM
JTY2K
Sep 7, 2005 06:49 PM
JTY2K
Sep 7, 2005 12:17 AM
JTY2K
Sep 4, 2005 07:37 PM
