Lashing Valves help?
Old Feb 29, 2004 | 02:11 AM
Slowwarrior's Avatar
Default Lashing Valves help?
I am getting ready to lash my valves on my Raptor tomorrow. I see there are different specs to adjust these to. Should I go for the higher or lower value? I thought about using the larger value the .15 and .20mm in case the valves were to keep tightening up but I am not sure if they will tighten anymore now that it has been broken in? What spec should i try for my valves? Will they tighten more now that its broken in or will they start to get more loose? This is the first time I have lashed my valves about 20-30 hours on my fourwheeler. I checked the intakes with a .152mm and all of them were too tight to fit that in between.
Old Feb 29, 2004 | 07:00 AM
Chilly's Avatar
Normally anything within the two limits will be fine, but there is no harm in going with the larger gap. it's better to have them on the loose side than too tight.
Old Feb 29, 2004 | 10:02 AM
sixsixT's Avatar
I adjust mine right in the middle .005" and .007" inches.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
