Pull Starting A Grizzly
Old Mar 1, 2004 | 08:45 PM
RstolzWi's Avatar
Default Pull Starting A Grizzly
I tried and my friend tried. Is there a trick to pull starting this beast? I can't hold on to the Handle.. ( only 25 miles on it)
Thank You,
Rick-Wi
Old Mar 1, 2004 | 09:25 PM
lafngas's Avatar
I would like to know also because my Kodiak pulls like a real BEAR!
Old Mar 1, 2004 | 09:26 PM
Raptorboy4life's Avatar
is the key on? is it in neutral? [img]i/expressions/face-icon-small-tongue.gif[/img]
Old Mar 1, 2004 | 09:28 PM
RstolzWi's Avatar
Yes Key is on and in Nutral
Old Mar 1, 2004 | 09:36 PM
lafngas's Avatar
The Grizz nor the Kodiak has a decompression chamber so I know thats why they pull so hard. My Kawie has a decompression lever on top of the head so It pulls easy. I have know Idear why Yamaha didn't do the same!????
Old Mar 1, 2004 | 09:45 PM
outdoornut's Avatar
I pull started mine just to see if I could do it. No trick, just pull on it.
Old Mar 1, 2004 | 09:53 PM
TRLYFZ450's Avatar
Try to pull it over slow just past the compression stroke. Let the rope in and pull it over fast it should start. My old warrior with 11 to 1 compression if you just pulled it would rip the handle out of your hand.
Old Mar 2, 2004 | 05:21 PM
hondabuster's Avatar
Yep, thats how its done. You got to get just past the compression stroke, reel it in,and then pull,that way the flywheel helps you get past the next compression stroke.
Old Mar 5, 2004 | 01:10 AM
GrizzlyGuy's Avatar
My 03 Grizzly has a decompression lever on the front upper left side of engine. Guess you purchased a after market Grizz...........he,he,he,he,he,he
Old Mar 17, 2004 | 09:20 PM
Leinad's Avatar
Quote: "My 03 Grizzly has a decompression lever on the front upper left side of engine. Guess you purchased a after market Grizz...........he,he,he,he,he,he"
BTW, the '03 Grizzly does not have a decompression lever. At least mine doesn't and my Shop Manual does not depict anything ressembling a decompression lever.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Dammar
Nov 14, 2015 07:41 AM
Scott-Leigh
Jun 6, 2015 09:10 AM
1000gade
May 27, 2015 12:37 PM
PLEA$URE
8
Jan 31, 2000 10:55 PM
