warrior / clutch
i think i have a clutch problem but i am not sure since i am a newbie to sport atvs when i am riding and the atv goes under a load its like it is in neutral then i let off the thorttle and it pops and catchs does it sound like the clutch to you guys and if it is the clutch which one should i buy
thanks alot
thanks alot
Sounds like it could be the clutch. First, make sure it's adjusted properly. Ya need to have the proper amount of "free-play" in the cable/lever as mentioned in the manual. If there is no free-play it can make it slip. If it's adjusted correctly and it still slips it's probably wore out.
Being a 2001 it is likely OK assuming typical amount of riding - Lots of hard miles ?
Check here for the service manual if ya dont have one....
Source for PDF Service Manual
okay i took it to a local shop today and they told me that it is the clutch what is the best choice for a clutch oem or aftermarket {if aftermarket which is the best choice} i want something that will last
my buddy at the shop told me to go oem please input thanks
When i had my warrior i used the tusk clutch from rockymountainatv.com. Its only like 24.99 plus shipping, and while your in there you might as well change the springs , Just get the clutch kit its only 39.99 or something. Anyway the cluch worked great. Also might be a good idea to get a clutch cable also, well woth the 8 bucks.
