skid plates for wolverine!!!
Old Mar 11, 2004 | 10:46 PM
Madwolverine's Avatar
Default skid plates for wolverine!!!
I'm thinking about putting some skid plates on my wolverine. I noticed that maier sells some plastic skid plates. Anyone ever tried these?
I like the looks of the dg aluminum plates but not the cost. How much does a set of aluminum skid plates weigh? Do they bolt up with no drilling required?
thanks
Old Mar 12, 2004 | 12:51 PM
wolv03's Avatar
one of the first things i did when i got my wolverine was put on a skid plate . it is to exposed on the bottom . i bought the plastic plates because i wanted to add as little weight as possible . they bolt on in a couple of minutes . i have hit some stuff pretty hard and they have held up for being plastic . i forget how much i paid for them though .
Old Mar 14, 2004 | 03:53 AM
Wolverine350R's Avatar
Definity get some skids, I had a small chunk out of the bottom of my motor and a bent frame tube befor ei got one on mine. The aluminum one should bolt up with no drilling (mine did but I'm not sure where it was bought from), I don't know about the plastic ones but I think I'll try some on my next quad.
Old Mar 15, 2004 | 12:42 AM
HOBERT's Avatar
Get the PRM heavy duty aluminum. I have the a-arm guards, belly pan, and swingarm plate they may cost a little more but well worth the money. First alum. belly pan I went cheep. The center frame rail got bent up against the bottom of the motor. I bent the bar back away scraped the skid plate and bought PRM. Never had the problem again.
Old Mar 15, 2004 | 02:04 AM
CTATV's Avatar
I extremely highly reccomend the highlifter skidplate. I got the set with the dimondplate bash guard and oil filter guard and the full belly skidplate. Its competatively priced and I have beaten the hell out of mine. I mean really romped on it and I have never had a problem. I ran over a large rock once at like 25 and it put a dig in it but didnt do anything too serious. If you get the dimondplate it also gives you a mean and unique look. Dont forget to get the oxlite or some other type of CV boot/joint guards as well. The last thing you want to do is tear a CV boot or mess up one of the shafts. I never got a guard for the rear diferential and havent had a need to so far but thats up to you. www.highlifter.com
lonerider856
Oct 13, 2023 03:45 PM
Oct 10, 2015 10:20 AM
tysonbully
Sep 28, 2015 02:30 AM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
