blaster piston kit?
Old Mar 12, 2004 | 01:08 PM
wanaply21's Avatar
Default blaster piston kit?
ok i want to order a new piston for my bike but was wondering does it really do me any good, will it run faster? i would also like it if they had it www.vitosperformance.net cuz they have other stuff that i want to order such as degree key, reed spacers, and wheel spacers but could u state the size and everything cuz i have no experiance with a piston! thx for everyones input!
Old Mar 12, 2004 | 03:00 PM
sAyIt_fmf's Avatar
Are you changing the piston because the bike won't run? or are you just looking for more power?
I cannot help you with size required for you...that has to be determined by removing your cylinder and taking some measurements.
Old Mar 12, 2004 | 03:49 PM
wanaply21's Avatar
no it run perfectly fine i just want more power, will it give to me or not? and its a stock bore still
Old Mar 12, 2004 | 04:29 PM
sAyIt_fmf's Avatar
If the bike still runs good...I would not even mess with the piston yet...use the same one till it no longer works.
You could always have the head milled for a bit more compression...it will cost a ton less than a new piston.
Reed spacers might give a bit different feel on the throttle...but that's questionable depending on who you ask.....I was not aware they make a degree key for a blaster.....wheel spacers will give you a bit more stability.
From the looks of you sig...you seem to have a nice blaster. The only way I can see that you are going to get a noticable increase from your current mods would be to do an all out 240kit witha larger carb or the likes.
Old Mar 12, 2004 | 05:05 PM
wanaply21's Avatar
i dont have the money to do anything drastic like that if i did dont u think it would already have been lol but thanks for ur input, much appreciated (mmmk piston off the list)
Old Mar 12, 2004 | 11:11 PM
dragracer789's Avatar
just buying a piston isnt going to give you any noticable power.
Old Mar 12, 2004 | 11:42 PM
wanaply21's Avatar
ohhh ok, i thought if it would be a lighter piston then i would get more power cuz its lighter or are they about the same anyway?
Old Mar 12, 2004 | 11:46 PM
Rider1169's Avatar
well, the cheapest u can do is get it machine drilled to a 220 or w/e u want, thats 50$ at cheapest. then for 60$ u can get piston and rings and everything else u need. so for under 200$, u can bore it and make it pretty fast, run it now till it goes tho.
Old Mar 13, 2004 | 12:10 AM
wanaply21's Avatar
well how about a 240 sleeve? then get the piston i can get my rents to pay what it cost to get it done
exmotocrosser
Sep 13, 2019 06:12 AM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
nastyblaster100
Sep 13, 2015 01:19 PM
