help installing a tether switch
Old Mar 17, 2004 | 10:32 PM
yamaracer's Avatar
Default help installing a tether switch
I just purchased a tether switch for my new yfz450 and was wondering if anyone knew how to install one or could tell me where i could look for some help. Any help would be appreciated thanks.
Old Mar 20, 2004 | 06:59 PM
BadToTheBone's Avatar
is ia a pro design kill switch? If so you can go to their web site and they have instuctions. I just bought one for my friend's quad and will be installing it sometime this week on a yfz450. I'll keep you up to date when we finish if you haven't figured it out by the directions yet. I know that it had to be connected to the coil wire on my raptor but not sure right now for the 450
Old Mar 24, 2004 | 11:53 PM
yamaracer's Avatar
mines made by Tusk off road i think i found a way to hook it up but havent had a chance to try it yet. ill check out those directions. thanks
Old Mar 25, 2004 | 12:16 AM
spacollie's Avatar
Should be a white wire in the harness by the left side headlight, tie into that and ground the other to frame. Use a headlight mount bolt or such.
Old Mar 25, 2004 | 10:52 PM
yamaracer's Avatar
thats what i thought thanks for the help
Old Mar 27, 2004 | 08:35 PM
yamaracer's Avatar
i wired up my tether switch and when i tried it to see if it worked right it worked backwards of what its supposed too. does anyone know what i did wrong.
Old Mar 27, 2004 | 09:45 PM
did you use the right wire and not the ground?
Old Mar 28, 2004 | 12:57 AM
yamaracer's Avatar
i tried both of the wires and it worked the same either way.
Old Mar 28, 2004 | 01:27 AM
Hozed's Avatar
according to my dealer there is a special teather designed for the yfz450... just like the one they use on the bikes i guess... its 80$
i wanted to just run my old teather so i dont hafta buy another one... but i dunno... ive never heard of others running a special teather so i am sure there is a way to get the pro design to work.
bradco
Aug 21, 2015 08:11 PM
frostphase
Aug 19, 2015 07:11 PM
WILLLANE8302
1) Engine problems..
Aug 7, 2015 08:24 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Bratman2
Jul 23, 2015 12:36 PM
