clutch on a warrior?
Old Mar 24, 2004 | 09:45 PM
Jordanw's Avatar
Default clutch on a warrior?
How do u no when u need a new clutch and how much do they cost? Can u put them in ur self or dose the dealer have to put them in and if so is it expensive? If u put it in is it hard?
Thanx!!!!!!
Old Mar 24, 2004 | 09:52 PM
PineyPowerwpww's Avatar
Well when you have your clutch fully adjusted and there is no more adjustment.the clutch will start to slip then its time for a new one. as for ewhat clutch to use i heard the barrnet dirt digger ( comes w/ complet set of everything you need) is your best way to go.As far as doin it ur self if u have a little bit of mech. skils you should be able to pull it off..
Old Mar 24, 2004 | 10:17 PM
XR650Warrior's Avatar
oem clutch disks will hold far more than the so-called aftermarket I have found, just have your steel plates bead-blasted and go in with stock fibers, and you'll be fine, I'm running 70+ H/P on oem fibers and have had no problems, just run the heavy duty springs with the set-up.
Old Mar 27, 2004 | 08:34 PM
yamahawarriormods's Avatar
yes, you can do it youself but i would recomend a manual and a inpact wrench will make it alot easier
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
jbrewster94
Sep 23, 2015 04:16 PM
