how unreliable will shaving the head make a bike?
Old Mar 29, 2004 | 11:01 AM
Shav0's Avatar
Default how unreliable will shaving the head make a bike?
but to make sure its done right, what all has to be done,
thats what i have been wondering.
i just rebuilt it (with stock parts) and dont want to have to go back and change everything. i also only have access to 92 octane gas
Old Mar 30, 2004 | 12:13 PM
Chimmer's Avatar
shaved head will affect cam timing, make piston to valve clearances tighter, raise compression, may result in need to run race gas, soooo, I would say unless you really know how to adjust/compensate, it will affect reliability. If done right, it will not affect reliability & will provide more compression. I would just order a higher comp piston, jmo.
Old Mar 30, 2004 | 12:24 PM
Shav0's Avatar
i dont need to worry about timing chains and cams.
i'll leave that stuff up to the thumpers. I dont want to rebuild again that is why im not ordering a high compression piston.
Old Mar 30, 2004 | 12:39 PM
Hiram's Avatar
you can safely remove -.020 off the stock head with no porting or if you have porting you could then go -.030 off, anything more and you will have to have the squish band recut and depending on the compression psi have to run higer octane fuel.
Example: I currently have -.030 taking off my head along with vito's power pistons to give me a total of 165 psi of compression with +4 degrees of timing advance and this is borderline between pump gas and race gas but I run on 93 pump gas with no problems so far.....knock on wood!
Old Mar 30, 2004 | 12:51 PM
  #15
Shav0's Avatar
I was told that you can safely remove up to 0.040 from the head on stock piston and pump gas because the stock blaster only has a 6:1 compression ratio. The stock head is 22cc and can be taken down to 17cc by removing 0.040.
Doing this will only raise the compression to about 145psi
tycobb
ATC 3-Wheelers
Oct 23, 2015 07:37 PM
yagerzzz
Jun 24, 2015 07:45 AM
hugemoth
Jun 4, 2015 02:56 AM
blaze_master
May 26, 2015 11:18 AM
dosthoff
Jul 29, 1999 11:13 PM
