Hydro Brakes on a Blaster?
Old Jul 18, 2000 | 03:00 PM
razormazer's Avatar
Blaster brakes suck! I want to make my Blaster have better brakes, is there anyway to outrig it with hydro discs? Also, has anyone used a set of sintered metal pads on the rear? I really have to get some more braking power!
Old Jul 21, 2000 | 12:25 PM
blaster18's Avatar
i had a mounting plate mad out of aluilum for the caliper that i used it was off a motor cycle, and welded some brakets for the mastercylinder and used a lt250r brake pedal.
Old Jul 21, 2000 | 01:48 PM
hot_shoe_cv's Avatar
(1)I don't know of any real improvement you can make to mechanical brakes assuming the adjustment is correct & the brake rods are not binding. (2)Sintered pads will last longer & inhibit glazing but won't help as far as the actual operation of the brakes is concerned. (3) There are hydraulic kits available for Blasters. They aren't cheap & I don't know how well they work.
You have to look at it this way: The reason the Blaster can be sold at under $3000 (mslp) is because it doesn't have all the bells & whistles of more expensive quads.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
