Non starter
Old Apr 4, 2004 | 06:52 AM
Shiney's Avatar
Default Non starter
My Grizz 600 over heated and now fails to start, when I try it just backfires there is a good spark at the plug and fuel is getting through. I have adusted the carb but still get the same backfires.
Has anyone got an ideas about this.
[img]i/expressions/face-icon-small-sad.gif[/img]
Old Apr 4, 2004 | 03:38 PM
UltimateAussie's Avatar
Default Non starter
How long did you wait to try to start it after it over heated. Maybe the cylinder expanded and never contracted. id dont know if this is possible but if that was the case. you might try to check the compresion. Just an idea.
Old Apr 4, 2004 | 06:14 PM
Shiney's Avatar
Default Non starter
I tried to get it going about half an hour after, I,ll check the compression thanks for the advice we will see what the outcome is.
Thanks again [img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 4, 2004 | 07:59 PM
XxDumontRaptorxX's Avatar
Default Non starter
Half an hour isnt much time to cool off, make sure you have no air leaks, or the carbs didnt pop off when it backfired, mine popped off once after a backfire
Old Apr 5, 2004 | 02:27 AM
hondabuster's Avatar
Default Non starter
check the valve adjustment.
When a motor is overheated, it can cause lots of problems, like a head gasket. Hopefully this isnt your problem, but if the valves look good, and it still wont start, check the compression.
Johnny Mac
Aug 15, 2019 03:13 PM
Lucas Bohanan
Sep 29, 2015 01:16 AM
wrencher82
Sep 28, 2015 10:02 PM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
