Help! Buying banshee!
Old Apr 5, 2004 | 12:03 AM
4x4eva's Avatar
Default Help! Buying banshee!
I am looking into buying a used banshee. Around a 2000. This would be the first 2-stroke I have owned. So How can I tell if the engine is in good condition? I doun't know how a good 2-stroke is supposed to run. What other things should I look out for when buying a 2000? thanks
Old Apr 5, 2004 | 01:14 AM
Ernie660R's Avatar
It should start up within the first two kick starts. Drive it and make sure it goes through all the six gears.
Old Apr 5, 2004 | 09:14 AM
Shav0's Avatar
Like any bike it shouldn't have any pings, clicks, or rattles.
Old Apr 5, 2004 | 10:08 AM
AnimalMother85's Avatar
if there are any rattles, see what it is. My kicker is loose where it swings out, and it makes a rattling sound. Its no big deal. If it does make any noises, see if you can get it for cheaper than what he wants, unless he allready dropped the price to compensate. If i were you, I would get a LSR or laeger 250r spec frame, and go from there.
Old Apr 5, 2004 | 01:40 PM
lapeerbanshee's Avatar
it should be decently hard to kick start it to make sure it has good compression left.
Old Apr 5, 2004 | 03:04 PM
Hiram's Avatar
That's a poor way to test compression, I would use a guage instead, being that Banshee's are one of the easiest kick starting quads being that it is only pushing 175cc at a time. I can kick start mines sitting down and I run 165psi. If would check for frame damage and excessive play of the bearings and joints.
Old Apr 5, 2004 | 04:18 PM
it was just a reply
Old Apr 5, 2004 | 05:38 PM
Hiram's Avatar
Lapeerbanshee, your right it does work and I did it in the middle of a trail after a suspected meltdown just to confirm my suspecion, but I used my hand to push on the kicker instead of using my leg to get a better feel.
Old Apr 5, 2004 | 05:49 PM
cRazyJ's Avatar
if you want to fix your kick starter from rattling just move it clockwise on the splines, then i will be pushed up against side case and it wont rattle, but you can still kick it, my detent ball fell out too, theres no way to get it back in.
Old Apr 7, 2004 | 08:01 PM
ya your right i had mine in the shop for about a week and forgot how easy it was to kick
Cole Hadden
Jun 15, 2025 09:05 AM
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
