YFZ 450 oil leak...
Old Apr 12, 2004 | 12:28 PM
Tee's Avatar
Tee
Default YFZ 450 oil leak...
My bike just started leaking oil. It seems to be coming out behind the sprocket. It's bad when the bike is running, about three drops every five seconds at idle. If you hit the throttle, more oil leaks out. Has anyone else seen this problem? Only mods are Sparks pipe and jets and a UNI air filter.
Old Apr 12, 2004 | 12:41 PM
badchad's Avatar
If it's new and under warranty, take it back. If not, it should be an easy fix. Sounds like it's just the seal.
Old Apr 12, 2004 | 08:56 PM
Hebs's Avatar
Sounds like the same thing that happened to my yfz. I just took it in to the dealership, and they put a new seal on.
Old Apr 13, 2004 | 08:08 PM
yamahawarriormods's Avatar
sorry to here your yfz leaking oil... i hope its on warranty
NMills
Mar 21, 2010 07:21 PM
revenge143
ATC 3-Wheelers
Jan 25, 2008 11:37 PM
1986SuZuKiQuAdRaCeR
Sep 1, 2002 01:13 PM
URPREY
Feb 22, 2002 09:46 PM
