12 tooth on warrior
Old Apr 15, 2004 | 09:54 PM
ENSTYLE's Avatar
Default 12 tooth on warrior
well i put a 12 tootth sprocket on my warrior today it made a little difference in bottom but as much as
i figured the way everyone talks or is it just me
Old Apr 15, 2004 | 10:04 PM
soon2bBlaster's Avatar
i put a 12 tooth on my blaster but i didnt like it cause it made first too short and i still didnt have enough power to wheelie good in second so i took it off
Old Apr 15, 2004 | 10:07 PM
Rider1169's Avatar
yea, it should add a little cuz its easier for the engine to pull that gearing.
Old Apr 15, 2004 | 10:09 PM
ENSTYLE's Avatar
i am going to go try it this weekend / it does pull first easier
Old Apr 15, 2004 | 10:33 PM
BadDay350's Avatar
I love the 12 tooth on my warrior offroad. Hurt me topend on the pavement, but offroad it screams.
Old Apr 16, 2004 | 12:28 AM
maha350's Avatar
i put a 12 on and i love it. it has given me a higher top speed and better acc. i even raced a anther warrior with paddles at silver lake and burned it. all i had was my stocks. you dont notice it much but if you race against one without it you will see how much it changes it.
Old Apr 16, 2004 | 02:38 AM
Wheelsup's Avatar
I absolutely hated mine. On motor is did ok. No great improvment. And killed the top end. Felt like a lost a gear. 6th felt like 5th with the stock one. And on Nitrous it was even worst. Rapped the motor out way to much. I didnt like it on motor or on Nitrous i will give a thumbs down to me. Some may like but i didnt....
Old Apr 16, 2004 | 12:38 PM
yamahawarriormods's Avatar
i do believe the stock sprocket is a 13 so if you went down to a 12 you would loose top end but gain more low end [img]i/expressions/face-icon-small-cool.gif[/img]
Old Apr 16, 2004 | 01:55 PM
NLWarrior01's Avatar
What you say is true about dropping teeth on the front, but what he was saying is that on dirt he's picked up speed because the machine can rev up easier. I noticed myself on dirt that I can pull higher average speeds than with the 13T.
I stepped even further down in my gearing to 12/42. I haven't had a decent ride since doing that, so I dont' know if I will like it much or not.
I noticed a pretty big difference in my torque right off though, and also the way the machine rev's on trail rides. 6th used to be a putt along low idle gear, but now doing 60 or 70km/h sounds almost flat out. No trouble to tell it's not tho .. just pin the sucker!!! When I was using stock gearing I could pop the wheels in 1st and 2nd without much trouble, 3rd with some effort, and forget 4th or above. Then when I went to the 12T, 1,2 and 3 were easy as pie to pop up the front, and only a moderate effort for 4th. Lord knows what it will be now with the 12/42. I suspect my top speed will still be handy to 60mph, since with the 12/40 I was still hitting 63 without much trouble. that's plenty fast for me [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 16, 2004 | 07:34 PM
warrior387cc's Avatar
i've heard that higher gearing is actually a good thing with warriors so i'm running
14 teeth up front 42 rear and when racing agaist the same 400ex as before
i gained another length than i had on him before.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
