newbie needing info
newbie needing info
Lapeer if you fdont think you need to do a lot of maintenence you should ride a fourstroke.
wow did you even read my post, because if you had i said there is not as much maintainence as everybody says there is and that there is still more maintainence then a 4 stroke. but thanks for the advice on 2 strokes. but if you get a nice pair of pipes you'll get alot more power and you ATV will sound much better then a 4 stroke ( as a good man once said 4 strokes sound like big farts but i forget who)
newbie needing info
To be honest with you..if you have never ridden a clutched vehicle before...I would not even consider the banshee. Your going to be fouling plugs left and right until you learn to ride. I banshee is NOT a lug-a-around in first gear bike.
I would go with something a bit more forgiving...300-400ex, warrior...etc.
newbie needing info
The 400's are always a option and thwy look awsome.. Look at the z400.. there monsters..
Lapeer all i said what that if you dont think there is a lot of matenence ride a fourstroke. As for saying that meaning that fourstrokes sound like big farts?? i dont see it???? Do any of you besides lapeer?
You will keepy up with the kdx.. you should.. idk about a drag but you will give hima run for his money on trails
