Raptor carb issues
Old May 9, 2004 | 09:22 PM
fizzak's Avatar
Default Raptor carb issues
My Raptor likes to stall inder hard breaking-cornering. And the idle likes to rev. I sometimes have to come to a stop and release the clutch lever a little to slow it down then it settles down. Or I can turn the idle **** 1 full turn and then turn it back. Probably needs some adjustment somewhere. Anyone have any ideas as to what's wrong? Raptor has never had any carb work at all.
Thanks
Old May 10, 2004 | 06:24 AM
Ward660R's Avatar
You might want to check your choke plunger and see if it is rusted up and sticking. On the side of the carbs is a small black plastic nut where the choke cable goes into the carbs. Unscrew the nut and pull the plunger out, gently. If it doesn't come out very easy try some penetrating oil and work the plunger around if you can untill it frees up.
Old May 11, 2004 | 08:26 PM
fizzak's Avatar
You rock man, I did what you said and low and behold major rust and the spring is broken in three places. I'll send you a 12 pack of e-beer! Thanks
Old May 11, 2004 | 08:30 PM
RaptorOwner's Avatar
See, now this is what I like about this place [img]i/expressions/face-icon-small-smile.gif[/img] Way to go Ward660R!!! [img]i/expressions/face-icon-small-wink.gif[/img]
Old May 11, 2004 | 10:15 PM
fizzak's Avatar
Opps, its stuck in there and the cable came out. Sounds like a trip to the $hop. Hope I get it back in time for my Memorial weekend trip to Little Sahara. What a bitch.
bzdok1234
30
Feb 23, 2016 01:55 PM
tweeder
Jul 5, 2015 01:57 PM
JBibb
Jul 4, 2015 10:16 AM
Dabears1983
Jun 16, 2015 12:17 PM
RaptorGuy01
Oct 31, 2000 04:23 AM
