new raptor carb options
Old 05-18-2004 | 09:38 PM
1BADRAPTOR's Avatar
Default new raptor carb options
Ill find out saturday for sure, just got the pipe and will be starting this wekend and then going to pismo or peppers in pasadena for a test and tune....
I will have on video how she is, it looks bad as hell though...
  #22
Old 05-19-2004 | 01:53 AM
RaptorRacer1's Avatar
I agree with above posts that you are wasting money if you are buying NEW carbs just because you don't want to tune something up. Any aftermarket carb you buy, you will have to tune it initially to work with your setup.
If you were to get a cheap set of used stock Raptor carbs, all you would have to do is take your needles and jets out of your broken carb, pop them in the new used one, and you would be exactly where you were before it broke. That is as simple as you can get. Then you would have had $300-$400 left over to spend on other cool stuff.
But since you already ordered the Edelbrock, I think you will be very happy with it. I have been using one for over a year now and I will never switch back to the stock carbs. With the Edelbrock once you get it set good you will not have to change it. You can use it in the winter, summer, on a hill, at sea level and it will work just fine. It has instant throttle response, no hesitation or bogging like the stocker sometimes does. One thing, though. Unless you have a thumb-of-steel, you may want to invest in a ThumbSaver. The throttle action is VERY stiff. I will probably eventually go to a twist throttle because of it.
Good Luck with the new carb - and don't be afraid to call Edelbrock with questions. Jason and the other guys over there are great and very friendly. They have helped me out ALOT!
RR1
  #23
Old 05-19-2004 | 07:14 AM
Ward660R's Avatar
Originally posted by: 1BADRAPTOR
it's too long compared to my powerjet on the lectron, now i can do it at the hill with a screwdriver in about 10 min....
Mine has a thumb adjustable power jet, no tools needed.
[img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-tongue.gif[/img]
  #24
Old 05-19-2004 | 06:59 PM
Sorry for my ignorance, but what is a power jet? It is not the same as an accelerator pump is it? If it is not the same, do you know if the Edelbrock carb uses a powerjet.
Thanks,
RR1
  #25
Old 05-19-2004 | 10:38 PM
sixsixT's Avatar
Thanks,
RR1
Check it out. But a power jet is kind of like a main jet.
Lectron
Gtsordo
07-13-2015 10:38 PM
Dirtbikemike1
Technical and How-To Articles
10
07-12-2015 07:22 PM
Dirtbikemike1
07-11-2015 03:36 PM
black_thunder
07-09-2015 05:58 PM
Dirtbikemike1
07-09-2015 01:27 AM
Quick Reply: new raptor carb options
