Rear Axle Question. Problem
Old May 20, 2004 | 06:24 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
Default Rear Axle Question. Problem
I would just replace them.
Be sure to heat up you carrier for easier release/install of the bearings. (i let mine sit on top of the kerosene heater for 5 minutes or so)(they just about fell out)
Also, be sure to inspect the carrier for any damage where it may have come in contact with swingarm as it was spinning. (I had to re-chamfer the edges of the carrier,,,so I could get the old bearings out.
Buy new seals also.
Be sure to loosen the (2) set screws on the axle nut.
Old May 20, 2004 | 12:45 PM
OregonYamaha's Avatar
Anyone else have any thoughts on the video?
Old May 20, 2004 | 01:01 PM
RaptorRacer1's Avatar
That much movement can only be because the bearings are toast or, worst case, the carrier is damaged. Take the axle out and see what's up. Good thing bearings are not too expensive.
RR1
Old May 20, 2004 | 05:39 PM
RaptorOwner's Avatar
Originally posted by: FarmStud
Use couple of big cresent wrenches and a little locktite, a pipe wrench will really mess up the nuts. You have to torque them together, I mean tighten them in, them turn the inside one into the outside nut, mine came loose when I didn't do that.
I got tired of that and just purchased me an aftermarket billet nut for 40.00 and never have to torque it again.
Old May 21, 2004 | 02:34 PM
  #15
Bing's Avatar
Super Quad Patrol
RR1
they are more of a pain in the but if you wait,,,,and you may need a new carrier,,,,just replace thm now,,,,it will be well worth it.
Old May 21, 2004 | 02:42 PM
  #16
Lomax's Avatar
Yeah i would get into that rear end as soon as possible and get those bearings taken care of. If you let them go its could get very costly. A guy i ride with has a 400ex and he didnt replace the bearings when they went out, I just sold him an axle carrier yesterday that was somewhere around 300 bucks. It doesnt take long for bad bearings to eat up aluminum
Old May 21, 2004 | 03:55 PM
  #17
Well I decided I am just going to buy that Extended Swing Arm I have been wanting for a while. I have to have this thing back together and working in less then a week. So at this I don't have much time to waste. As you guys shed more and more light on it I do believe that the carrier is already toast. Last time I was out I found a piece of aluminum jammed between the sprocket hanger and the bearings. As though a very small piece of metal it causes great concern.
toonces
Oct 16, 2019 12:11 PM
Nelson
Jul 4, 2015 10:46 AM
hoopduerr
Jun 1, 2015 08:22 PM
blaze_master
May 26, 2015 11:18 AM
