Trinity Racing releases 780cc Stroker for the Raptor!
Old May 20, 2004 | 09:36 PM
  #31
selector's Avatar
Default Trinity Racing releases 780cc Stroker for the Raptor!
Originally posted by: marbleous
I will be in Utah,friday-sunday. Look for me in red rail.
Can't miss that thing - even if you're blind! Can't wait to see you run the hill w/ it.
Old Jul 21, 2004 | 10:08 AM
  #32
TheRaptorMan's Avatar
So how much is the stoke on a stock bike? They are going to 90mm so how big of a plus on stoke is that?
Old Jul 21, 2004 | 10:55 AM
  #33
garyc660R's Avatar
Stock stroke is 84mm. The crank probably comes within 1/4" of the cases with a stock stroke....maybe they are slightly clearancing the cases?
Old Jul 21, 2004 | 10:58 AM
  #34
So it must be a 6mm stroke kit.... what is the pow roll 770? A 5mm kit? I am going to try to find out some more info on it. May call Harry up, thanks for the info gary!
Old Jul 21, 2004 | 11:08 AM
  #35
garyc660R's Avatar
One thing about that much stroke is it's gonna hurt reliability no matter what.....unless a much longer rod is used. This is whyCylinder side load is gonna be increased a ton.....creating more friction and requiring more rebuilds. This is why Powroll gives a disclaimer about the stroked Raptor engine on their web site.
Old Jul 21, 2004 | 11:19 PM
  #36
SpDdEmOn's Avatar
Why dont some of you boys just send him the crank, and the cylinder for the resleeve and then run the Craycraft head intake setup on it??? It would be scary fast. That way the kit would make the full potential horsepower. From what you guys say, Trinity isnt getting the high power numbers out of an engine with the same displacement as the other engine builders, well if its the same dispacement and compression it has just as much potential, so just dont let him do the headwork and you can have all the horsepower you want. I dont know that Trinity isn't a good place to go, I'm just going off of what you guys are saying.
Old Jul 22, 2004 | 12:10 AM
  #37
DaBeechMan's Avatar
because it sounds like the crankcase needs to be trenched, hense the reason why they want the ENTIRE motor
Old Jul 22, 2004 | 02:22 AM
  #38
thunderalley400ex's Avatar
From what I understand Mark at Mad Racing has re worked Frank's 800cc stroker and has finaly got it to run very strong. We will see next weekend at Dumont...
Old Jul 22, 2004 | 02:43 AM
  #39
MURDR's Avatar
You guys are making me second guess yoshimura now, because i have a z400 and the said there 450 kit after they have done the work and a 47mm carb creates 55hp and 44hp the stock carb. Do you guys think this is true. Yoshirmura said its the same set up as that Doug Goust rides with.
Old Jul 22, 2004 | 04:10 AM
  #40
RoostKing's Avatar
DaBeechman, you still 'round here?? Figured you would have got tired of the same ol, same ol..
Roostking...
