Does a warrior really rev?
Old May 21, 2004 | 07:41 PM
JakalWarrior's Avatar
Default Does a warrior really rev?
Just for kicks, pull the torque stuffer out and see what happens [img]i/expressions/face-icon-small-smile.gif[/img] Another thing, DO NOT use the needle from the jet kit, ive only heard bad things about them. Use the stock needle on stock setting more than likely. My guess is you put on the pipe and torque stuffer, then followed the jet kits instructions which landed you rich because the torque stuffer made the aftermarket pipe almost as restrictive as the stocker. If you for some reason think you need more bottom end after you remove the torque stuffer, first try removing discs from your WB pipe, if that dosent help then go back to the torque stuffer but use stock or barely above stock jetting.
Old May 21, 2004 | 07:43 PM
87Banshee250sx's Avatar
Hes screwed..
Old May 21, 2004 | 07:45 PM
warpigs's Avatar
The stock Warrior has a tendency to float the valves at high RPM, and make it sound like its not really reving hard. I read this in Dirt Wheels some time back, they a said a valve spring change to performance springs,(there a little under a hundred bucks) will solve the problem. It definitly does solve the problem, because I did the change, and now it feels like it revs to the moon.
Old May 21, 2004 | 08:47 PM
DS650BajaRunner's Avatar
I was planning to remove the torque stuffer anyways I am running 24 discs and im going to put a 12 tooth sprocket so i dont really need it as for the performance springs I will have to check that im running a very low budget. And I still havent correctly adjusted the jets so that might have something to do with it.
so the thing i should do is
1. Remove the troque stuffer
2. Re adjust jetting
3. Buy some performance springs
Boy its going to be a long weekend Thanks guys.
Old May 21, 2004 | 11:01 PM
  #15
Dont bother with the springs until you buy a big cam. With a stock cam and springs the valves dont float till long after the power has ended. You would have to be trying to overrev it to get it up there.
Old May 22, 2004 | 12:46 AM
  #16
mascman's Avatar
24 discs are way too many.
Alba recommends 11 or 12 and their jet (mine didn't come with a needle) for max HP from their pipe kit.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
