It's gone again :(
Ya, it vibrates pretty good, and behind the knocking you can hear a constant noise that sounds like a loud gear type noise. Could be something hitting a gear or 2 things hitting together, it's alot faster and quieter than the knocking.
Originally posted by: Yamaha660R
Yep. It's a safe bet to say you need to go right to splitting the cases and see what is the problem.
It could be something like the counter ballancer sheared the key.
#15
The first thing I would do is put a wrench on the crank and move it back and forth to see if you can get a feel of where the problem might be. If you think it might be a sheared key then all you have to do is pull the clutch cover off.
#18
Originally posted by: DaBeechMan
Them damn 4-strokes...lol
I wonder if bigbubba knocked on wood after he said he beats up on 250s without any problem? [img]i/expressions/face-icon-small-smile.gif[/img] jk
#20
I can almost bet one or two of your jug bolts stripped out of the case. The only way this can happen is if the bolts were installed in the position of the jug. There are two short and two long bolts, and if there are not in the right location that is what will happen. I have already seen two 686 Rappy's have the same problem bigbubba. I hope you get it up and running soon.
