HELP...water in engine
Old May 25, 2004 | 10:51 PM
erincourt5's Avatar
Default HELP...water in engine
ok...heres the deal...i washed my yamaha banshee YFZ350 and i ended up getting water in the engine its a 2 cylinder...i was wondering what i can do about that...please email me back asap. THANK YOU
Old May 25, 2004 | 10:54 PM
Yamaha4eva's Avatar
lol this a forum for atvs u dont think we dont know a shee has 2 pistons?, well its hard to help because i have no idea where the water went in (likely the pipe) so take out the air filter (another possibility) and tip it nose end up and see if any water comes out...if not i have no clue!
Old May 25, 2004 | 11:03 PM
Eric250EX's Avatar
wait its a 2 cylinder? lol
well when ever i was my quads i tilt them back so that takes car of getting the water in the pipe... but i guess u got water in the carb, just lit it site in the sun. it should evap soonoer or later.
Old May 26, 2004 | 08:42 AM
Yamaha4eva's Avatar
if thats the case itll prolly rust...and get moisture in there, hes gonna end up taking it apart anyways
Old May 26, 2004 | 11:25 AM
Red400EXRod's Avatar
Pirate Biker
Limping Rider!
Drain the float chambers on the carbs, there should be a bolt on the bottom of your carbs, remove this and drain them. Then remove the spark plugs. With the plugs out kick it over quite a few times to clean the cylinders of any water. Put in NEW spark plugs. You should be good to go.
IF you washed your 'shee with a pressure washer you may have blasted water right throught the gaskets. You will need to replace them. Don't ever use a pressure washer on your engine.
Old May 26, 2004 | 12:25 PM
wanaply21's Avatar
i was ridin in trails one day with a k&n clamp on, on my blaster and hit a puddle and bogged ot completely and wouldnt kick, and we were at least 30min ride from the house and had no time cuz we were on the RR tracks and CSX would roll by anytime so we found ourselvel a nice hill and jump started it so it pumps all that extra water in it, but u have tools so u can drain the floats and u should be alright but this is a last resort and it worked for me and run just as good as ever afterwards
Old May 26, 2004 | 12:30 PM
sAyIt_fmf's Avatar
If you suspect there is water in the engine....Please do yourself a favor and change the oil a couple of times. The oil will be somewhat milky in color if water is present.
Drain and flush the carbs as well.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
austinwhitton
Aug 11, 2015 06:21 PM
Jul 30, 2015 09:39 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
