Squeeking shock
Old Aug 1, 2000 | 10:42 PM
Kerplunk's Avatar
How can i stop a sqeeking shock on my y2kodiak?? I sound like a worn out bed on the trails. I've tried spraying WD up inside but that didn't help. Any ideas? TIA.
Old Aug 1, 2000 | 11:53 PM
PC_350_Warrior's Avatar
Yea, my '96 Warrior does the same thing! The back shock is really squeeky. I dont know what to try either! I've done WD-40, but that didnt help too much. Maybe someone will reply and help us!! Sorry I couldnt help!
Old Aug 2, 2000 | 12:06 AM
hot_shoe_cv's Avatar
Unless you have positively determined that it is the shock, you might check the swing arm pivot bolt. They normally aren't lubed too well at the factory.
Also, WD40 is not really a lubricant. It is basically a rust preventative by way of displacing moisture.
Old Aug 2, 2000 | 12:07 AM
WyoRider's Avatar
Easy, pull out the bolts at the top and bottom of the shock and put some grease in there. There is a round "ball" with a hole through it for the bolt, that needs lubed. You will see when you do it; the shock end goes around the ball and the bolt goes through the ball. That's how it is on my quads, at least.
Old Aug 2, 2000 | 12:56 AM
Blastermon's Avatar
Maybe the bushings? Just a thought.
Old Aug 2, 2000 | 03:07 PM
Kerplunk's Avatar
Thx for the replies.. I am sure it's in the shock, I've lubed every moving part I could access already. Tonight I'll pop it off and grease her up like a 10 cent ho!
And yea i know WD-40 is more of a rust inhibiter but it will lube those hard to reach places when you can't fit a finger full of grease!!
Old Aug 5, 2000 | 08:26 AM
Rammer's Avatar
Usually it's the spring rubbing on the shock body. Yamaha replaced the assembly on my buddies '00 Big Bear under warranty.
Old Aug 5, 2000 | 03:16 PM
Kerplunk's Avatar
I took it off and all the linkage was well lubed, it was deffinatly in the shock.. I turned it up side down with out paying attention(I guess your not supposed to do that), but some oil must have ran up top where it was squeaking because when I put it back on it was gone. I was going to try and take it appart but it's a mfg sealed unit.. anyway, no worries, problem solved!
BTW, on mine, the shock has a plastic cover keeping the spring from rubbing, but mine wasn't rubbing anyway...
Thx for the replies!!
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
bigred20653
Sep 19, 2015 02:11 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
