Part # of K&N filter for breather w/Pro Flow intake?
Old May 29, 2004 | 11:57 PM
adamnieman's Avatar
Default Part # of K&N filter for breather w/Pro Flow intake?
I plan on installing a Pro Design style intake on my Raptor soon. I see most install a small K&N filter to the breather hose that normally goes to the air box lid. Is this the best setup or can you modify the airbox and connect the hose to it? What is the part # for that filter?
Also, I pan on going to 145/150 main gets and alittle richer on the mixture screws. I will be running no lid with stock muffler for sound restriction reasons. Is this a good starting ground as far as jetting goes? I am around 1,500 ft. elevation. Thank you.
03 black and red Raptor
PRM grab bar and rear skid
Pro Design billet shifter
stock tires for now...again...thanks Pudljumpr!
Old May 30, 2004 | 12:36 AM
sixsixT's Avatar
The jetting sounds about right. Check out the pics on my page for the filter.
Old May 30, 2004 | 02:38 AM
SpArX's Avatar
I put a hole right under the filter in my airbox ahead of the filter brackets that hold it up from the bottom. I them put a similar breather to sixisixt's but without the bracket with the hose connecting from the bottom of the air box where the breather sticks through. Looks clean, and it's hidden. the only way to know it's there is by pulling the filter out, or by looking at the bottom of the airbox to see that the hose runs ahead of the airbox drain. If you run an airbox prefilter like I do, I think you could just hook the hose to the airbox and even go without the K&N breather. I did both, just so if I don't run the airbox prefilter I don't have anything to worry bout dirt getting in there.
lightninboy
May 16, 2021 09:52 PM
TheHood
Aug 8, 2015 05:49 PM
Captjay
Jul 23, 2015 12:33 PM
cSchwartz
Jul 9, 2015 02:43 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
