Bruin Reverse rev-limiter
here is the way around it. i just did this on my kodiak last night. I am pretty sure it will work for the bruin. You first must take the air box completly off to have access to the trans from the top. once it is off you sould see a couple off sensors about 4" back. at this point, turn the key on put it in rev. you are going to have to find the reverse sensor. i believe it is the one all the way to the right (looking at them from the back of the bike) start by pulling the sensor connector off the far right sensor. the reverse light should go off, if it does it is the reverse sensor. if not put it back on and try another one. once the light goes off you have found the correct sensor. when you find the right one put the rear end off the bike in the air for a test run. first run it in rev with the sensor connector on and the rev limiter witll be on. now take the connector off and run a wire from the connector to a ground. the rev. light should go off and now give it gas, there should be no limiter. I accomplised overcomming the limitor by haveing a override pushbutton switch grounded to the bike, and then spliced into the reverse sensor connector. this way you can have ithe limitor on or off.
let me know if it works
http://forums.atvconnection.com/mess...hreadid=434842 This is how to do it. Pics are on my page......Just ask if you need any help.
