Help with Blaster please...
Old May 31, 2004 | 10:23 PM
Blaney's Avatar
Default Help with Blaster please...
idles fine, but bogs out as soon as you give any throttle...if you "feather" it to get it past bog point, it seems to run ok once you get it into a higher rpm's...I have cleaned carb, disassembled and put back together...air filter is clean, it ran just fine last fall, so jetting shouldn't be a problem...please help, I am about to go nuts with this thing...
Old Jun 1, 2004 | 10:58 AM
potentpete's Avatar
Do a compression check, and check the specs of the primary coil with an ohm meter, it might be one of the 2.
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
