blowed up the warrior
Old 06-13-2004, 07:50 PM
yaaaaaa's Avatar
Default blowed up the warrior
blowed up my 98 warrior the other day because of the oil pump went out on me. I am wondering how much i can sell it for. Pro-taper bars, brand new tires and aluminum rims, new plastic, K&N filter with proflow intake, nerf bars. I believe that is it. I was thinking 500-600 is that to low ya think?
Old 06-13-2004, 08:06 PM
JakalWarrior's Avatar
Hehe, mine ate an oil pump. I fixed it all and put a new one in it. Then it ate another one. If you want to fix that motor what you need to do is tear into it and split the cases. Find what it is thats coughing out metal to tear up the oil pump, and put it back togther. Did it fry the top end or the crank? Mine always just fried the rockers and cam. That will cost about 250 to replace, the oil pump about 90 bucks, then about 150 to pay somone to put it back together if you cant figure it out (NOT a dealership). Then you can sell it for a good bit more or ride it.
Old 06-13-2004, 08:26 PM
Daranello75's Avatar
mine it full of metal bits, when I drain my oil! Am I up for an oil pump faillure?
Old 06-13-2004, 09:12 PM
yaaaaaa's Avatar
is there filings in your oil filter? if so then yes you are in for a bad ride.
Old 06-14-2004, 12:26 AM
HMFIC's Avatar
I would go ahead and clean the filters good and fill it with fresh oil. Maybe that will let you ride a little longer.
Barnsnelbon
09-27-2015 03:07 AM
Bernhard
09-25-2015 12:45 PM
xreynolds95
Technical and How-To Articles
09-21-2015 04:51 AM
Nosniborpapa
09-19-2015 07:07 PM
Quick Reply: blowed up the warrior
