98 warrior back together but has problems......
Old Jun 23, 2004 | 04:53 PM
XJ4ME's Avatar
Default 98 warrior back together but has problems......
ok guys i just got done rebuilding my 98 warrior. It now has a .40 over wiseco piston,new valve seals & valve job, and fresh frame paint, so no more smoking. When i was ready to start it i had no fire so i went over all of my connections and grounds and made sure they were good. It still would not start so i had my dad try and pull start me. About the third rotation of the tires it started. Now i have been driving it 5 minutes, let it cool, 10 minutes let it cool and so on. Thing is now it will start with the button?????Is it the stator thats causing it to do this?? Im not sure what it'll do when its completely cold, ill find out tomorrow. It also will start running badly when i hit high rpms so to keep it running i have to feather the throttle and then it will be fine again after about 30 seconds. Any ideas or suggestions??thanks
Old Jun 23, 2004 | 04:56 PM
warrior68man's Avatar
If you pull started it and it started.....check for spark with the button...or doesn't it turn over at all. Best information I can give you until I find more info out.
Old Jun 23, 2004 | 09:53 PM
XJ4ME's Avatar
it turned over perfectly fine but didnt have spark when i turned it over. Once it was warmed up it starts right up with the button.
Old Jun 23, 2004 | 10:14 PM
87warrrior's Avatar
do you have nothing when u try to start it with the button? are you having like... neutral light spasms where sometimes it works? maybe it could be your battery?
Old Jun 24, 2004 | 01:46 PM
XJ4ME's Avatar
it working right now i have no idea why but it starts right up with the button now so i guess itll be fine
Old Jun 24, 2004 | 03:11 PM
87warrrior's Avatar
lol
Reactant
Mar 30, 2022 02:08 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
rcappie4
Jul 10, 2015 04:54 PM
Coryco
Jul 6, 2015 07:30 PM
