stock banshee vs stock kfx 400
Old Jul 5, 2004 | 05:21 PM
  #41
craZ400's Avatar
Default stock banshee vs stock kfx 400
Bulldogz400 is the only one who understands math, obviously. If you put a sheet of plywood on the front of a z, it will not achieve top speed, and thus will not hit the rev limiter. But if you did have enough power to hit the rev limiter, it would be the same top speed as a z without he plywood. By the way ImBack, how many "kids" you know with an associates degree in the Air Force?
if this is the case then why when i haul a trailer with my truck... it revs higher to go 80 mph that it normally does...
Is your truck an auto or manual? Automatics rely on fluid to transfer power from the engine to the tranny, where manuals rely on the mechanical clutch system. But try this, see how many rpms a manual tranny truck needs to maintain 55mph, then throw a trailer on it, and see. rpms of the engine translate directly to rpms of the wheels. The circumference of the wheel relates directly to how many feet per min you go reguardless of weight and resistance. When I said weight and resistance have little to do with top speed, I was refering to a z with a rider that can hit rev limit. If a rider can't hit 70mph, then he's not hitting 8500rpms is he? The engine will not turn faster than the drive wheels will allow and vice versa.
Old Jul 5, 2004 | 05:22 PM
  #42
therushnkid3's Avatar
sorry appx 28 but still that can't be right. and with quads 1 or 2 numbers off does matter when your talking horse power
Old Jul 5, 2004 | 06:27 PM
  #43
jed250's Avatar
Originally posted by: Imback
And I'd llike to know the age and education level of the idiot calling me kid.
Not only are you a kid but a pretty stupid one, you will only get a few more MPH out of your Z with higher gearing before the engine can no longer hit its maximum rpm due to wind resistance and therefore you wont go any faster no matter the gearing...Once you reach that point there are only two options that will allow you to increase your top speed, either you make your Z more aerodynamically efficient and pick up a little more speed or you mod your engine to make more power.I have read a few of your posts and can tell you this kid, you sure like to talk out of your @ss...
All this talk about wind resistance. Guys what ever happend to friction? That's a very powerful force that limits the efficiency of simple machines (such as the wheel and axle on the fourwheeler and then there's also the chain and sprocket). Why do you put oil (or WD-40) on your chain and sprocket? It lowers the amount of friction and increases efficiency.
Old Jul 5, 2004 | 06:31 PM
  #44
jed250's Avatar
Originally posted by: bulldogz400
Originally posted by: hondaracer305
So you guys are saying that if i put an elephant on a 300ex, and the throttle was completely pegged, lets say on a dry lake bed. It would go just as fast as a 100 lbs rider on an exact same 300ex? I mean, it must be right, right?
If this 300EX was able to take the elephant the SAME RPM's as the 100lb kid, then yes. But since it would never able to, this would never happen.
Look at gearing calculators. They ask 3 things, rev limiter, tire size, and gearing. The three variables that matter assuming the quad was able to perform with one object on it compared to another.
To relate that to Physics, it's calculating top speeds assuming friction and wind resistance (is that a form of friction?) are negligible.
Old Jul 5, 2004 | 07:01 PM
  #45
Imback's Avatar
Well having a degree is the least of my concerns right now, i dropped out of college to run our family business and am doing pretty good...
I have read some pretty ignorant posts on your part when it comes to ATVs, i guess having a degree didnt prevent you from missing out on a few things.If you were that knowledgeable you would never ever had made a post like this one;
And with gear swaps,and higher rev limiter a rappy could easily break 100mph.
Someone as "smart" as you seem to think you are would know and understand why you will never get a stock Raptor to hit 100mph no matter what gearing it is running...In fact you will never get a stock Raptor or any other sport quads on the market today to hit 100mph with gearing changes and a different rev limiter,they just dont have the power to do so.Put a 15 teeth front sprocket on a stock Banshee and it only picks up 3-4mph instead of the 7-8mph it theorically should. Why? The engine aint powerfull enough to reach the same rpm level it does with the stock 14 teeth sprocket.Why? Wind resistance or drag or whatever you want to call it and since wind resistance grows exponnentially with each mph you try to gain it just gets harder and harder to go faster.
Let's say a certain quad is able to hit 75mph in stock form (stock form meaning you changed the sprockets but nothing else),you mod the engine and add 10hp you now are able to gear it higher and gain let's say 10mph.Do you think 10 more hp is all you will need to allow your ATV to gain another 10mph? Nope you may need 20 this time and the time after that you may need 40hp and all and all...
I dont have a degree but i know a few things when it comes to making a quad go faster...
Old Jul 5, 2004 | 07:06 PM
  #46
craZ400's Avatar
Not exactly, calculating top speed in spite of resistance. They're not negligable, just not a factor cuz they're not enough to keep you from hitting the preset limit already in place on the machine. If the cdi was not a factor in the determination process, then friction and resistance would factor in, but this not the case. Top rpms of engine x gear ratios = top rpms of wheels,rpm of wheels x linear dimension of tire circumferance x 60/5280 = top speed in mph. So a better question than what is top speed of a z would be, how many rpms can your engine turn with you on it. If your quad can't reach top speed due to weight, resistance, etc., then it can't reach top rpm. Why is that so hard to understand?
Old Jul 5, 2004 | 07:07 PM
  #47
JohnnySplat's Avatar
I just posted something a minute ago, but sadly it didnt get approved, there were some "forbidden words" in it for you craZ. Anyway, if you guys want to argue about all this crap, and tell me that my numbers are wrong, then why dont you just post your own numbers? Afraid that somebody will tear them down like they sometimes do with mine? Btw craZ, if you want to drag and let me put your punk-@$$ where it belongs I'm available most of the summer, just PM me. Although it might be a long drive from Alaska to Oregon. Come to think of it, maybe the fact that you live in Alaska has something to do with your attitude, all that isolation from large groups of other atvers has gotten to your head. Just a little quote for you to think about craZ, "The numbers only go down if you don't turn the graph upside-down!" I think somebody as smart as you can figure it out.
Old Jul 5, 2004 | 11:40 PM
  #48
elraptor02's Avatar
If weight and wind resistance have little to do with top speed, then peanut butter and jelly have little to do with a peanut butter and jelly sandwich.
Old Jul 6, 2004 | 12:03 AM
  #49
hondaracer305's Avatar
Originally posted by: therushnkid3
Well i just got done reading all of the post in this topic and needless to say everyone one of you **** me off. For one i know for a FACT z/kfx goes faster then 64 BECAUSE i have clocked a STOCK 400EX at 65 which if all of you know your stuff the z/kfx is faster then a 400EX. Besides that I’ve hear from many many people z/kfx goes at least 70 and those HP numbers are way off for the z/kfx 26 HP now come on get real. And this talk of physics and stuff CraZ or whatever your name is, who in the hell cares you people got way away from the topic of this post
There’s to many of you 2-stroke loyalist, get with the times.i don't hate 2-stroke hell I’d take one, but now days the 4-strokes aren't slow. They’re getting faster and faster every year. The 4-strokes are getting a lot more efficient now days and their starting keep up with the 2-strokes.
But anyways i would say the banshee is faster then the KFX400. i have no clue what your talking about with strength though
Do i **** you off.
Old Jul 6, 2004 | 12:22 AM
  #50
bulldogz400's Avatar
Ok we are all basically agreeing on the same things! Let's straighten this up...
YES-Wind resistance DOES play a factor on top speed if that the resistance is enough to disable the quad from reaching its maximum RPM's that it may normally reach.
YES-If a motor does not have a rev limiter, per say a Banshee, these resistances will ALWAYS affect the ability to reach the speeds it may have been capable of say the day before with less/no resistance. My quad, however, has a rev limiter at 10,500RPM, and if reached at any time I am going as fast as I can go. Now a day with 15MPH wind going with me may help me get to this limiter faster, but with a 15MPH against me it will take me longer, but in the end, going the same speed AS LONG AS IM ABLE TO REACH THE SAME RPM'S!!!! I may only be 17 but this is one thing I am sure of...
Easy enough???
Russiankid- Nobody cares
