Yamaha badgcraper
Old Jul 8, 2004 | 07:40 PM
Mudisfun's Avatar
Default Yamaha badgcraper
Ive got a 96 yamaha badger 80cc quad and I'm just doin some regular maintenance stuff and gettin ready to sell it, and i'm redoin the front brakes/bearings etc...
So I got new brake shoes, took the old completely worn ones off, and now when i went to to put the brakes back together I realized that when the brake cables are connected, the brakes are partially engaged. I tried playin around with the little tightener on the handlebars, it got me a little bit of slack, but not enough. I just need enough cable to the brakes are disengaged enough to get the drum over the shoes.
Do I need new cables? How come they are now so short that the brakes are partially engaged?
Old Jul 8, 2004 | 09:11 PM
95wolv's Avatar
There should be some adjusters on the actuator arm on the drum, I've never worked on a Badger,but Blasters and other drum brake types have a threaded rod and wing nut that allow you to set the tension on each side seperate of the adjuster by the brake handle.
Old Jul 9, 2004 | 01:18 AM
Mudisfun's Avatar
Thanks I'll check that out.
buddieboy
Dec 9, 2016 05:50 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
jbrewster94
Sep 23, 2015 04:16 PM
Sep 23, 2015 06:23 AM
