Cam break in procedure
Old Jul 8, 2004 | 11:48 PM
lilMike's Avatar
Default Cam break in procedure
What is your opinion on how to properly Break-in a NEW Stage 2 cam in a Yamaha Raptor? Not breaking in a new piston, thats already installed, so just cam, valves, valve springs. Thanks.
Old Jul 9, 2004 | 12:13 AM
Doctorturbo's Avatar
GOT BOOST!
Don't let it idle and you will be fine. Take it out and ride it, but don't let it idle, it's very hard on the valve gear and cam if you do. I would not recomend running synthetic oil either. After 15 to 20 minutes your done.
Old Jul 9, 2004 | 12:29 AM
RoostItUp's Avatar
They should of sent you instructions on how to break it in! You can't let it drop below 3,500 RPM but don't rev it, keep it as close to that RPM as much as possible for I believe 20 minutes to a half hour.
Also, check hotcams website, they should have instructions on there.
Old Jul 9, 2004 | 01:47 AM
Catalac's Avatar
I'm installing a cam shortly and would like to know how do you tell it's at 3500 rpm for break in if I have no tach?
Old Jul 9, 2004 | 03:16 AM
RoostItUp's Avatar
Take a good guess or go buy a tach like they have for doing sound tests. I just turned my idle screw up till it sounded like the engine was over 3,500 and let er rip for a half hour. You just gotta have an ear for knowing what RPM an engine is at I guess...
Old Jul 9, 2004 | 11:31 AM
1LeSSRaptor's Avatar
I'm in the same boat as lilmike. Hey Bigbubba, is it just as good to crank the idle screw up, or does there need to be a load on the engine?
Old Jul 9, 2004 | 01:59 PM
RoostItUp's Avatar
as long as the engine is above the RPM range, it doesn't matter how you get it there as long as it's there. Personally I wouldn't risk not doing it like this, cams are expensive and so is repairing a broken engine.
Old Jul 9, 2004 | 06:02 PM
garyc660R's Avatar
I just turned the idle adjustment screw up too get the rpm's up on my stage 1 and 2. THen I let it set there for about 20 minutes.
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
nastyblaster100
Sep 13, 2015 01:19 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
Elkaholic
Sep 6, 2015 02:44 PM
