Clear Tube Methode;starving for gas
Old 07-09-2004, 02:05 AM
XxRaptorxX's Avatar
Default Clear Tube Methode;starving for gas
I just put a hot cam in my raptor and rejeted it(it was always a little white from factory). I set the floats using the clear tube methode but I found when i would race down the road it would suck the float boals dry. So i raised the floats and its runs good now, just when i take jumps or go over bumps fuel comes out the over flow lines, is there something wrong with my fuel delivery or whatever, or is this just the way it is.
Thanks for the help
Starter clutch went a few days ago, L&A designs clutch should be here in a few days
Old 07-09-2004, 04:07 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
Im in the same boat,,,my one way is down too.
You have to adjust the tangs so you are sure that the valve will open,,,and close properly (check it visually before you re-install)(to be sure the valve is closing all the way properly,,,and also opening properly)
gotta find the in between i guess
bottom line,,,you should be able to wheelie without dumping fuel,,,,and you should have enough flow to keep your bowls from running dry.
ReconBayou
10-31-2022 05:37 PM
10-10-2015 10:20 AM
2many2ride
09-27-2015 04:35 AM
Irishman301
09-23-2015 01:47 PM
CosmoM
09-21-2015 04:57 PM
Quick Reply: Clear Tube Methode;starving for gas
