Raptor gas overflow tube??
Guess I will start a new thread since I got the oil change taken care of. After the oil change I took the 03 for a 10 minute ride and when I got back and shut it off there was gas running out of the tube by the rear shock mount. It ran for a couple of hrs or more and this morning it was not running gas but it drained almost all the gas out of the tank. Any ideas on what that was and how to fix it?
Sounds like your float valve is stuck from dirt...Take your carb apart and clean them paying special attention to tne float valve area and making sure the slide up and down with no restriction at all..Sometimes they build up **** around them and you have to clean em up real good..I use a small fingernail file to sand the gunk off and a small drop of oil to make sure they move freely.(Hope this helps)[img]i/expressions/face-icon-small-smile.gif[/img]
It ran gas for a couple of hrs and then this morning it was not running out gas and did not run all the gas out of the tank so would that still be float sticking? It was hot enought last night for the fan to come on, does that make a difference? Thanks.
Sounds like the float valve. First, buy some non-chlorinated brake cleaner. Take the carbs apart and remove the floats and needle valves. Spray the crap out of everything, and make sure there is no sand or dirt inside. Put everything back together and try it. Is it only coming out of one overflow, or both carbs?
Today it is not leaking and I went for the same kind of ride as last night and still no leak. I guess it fixed itself! I will still do the carb clean.
How do you use compressed air? Where do you blow?
I would spray everything with the cleaner first, and then use compressed air. The c leaner might get most of whatever is in there out, and that way the compressed air won't force any more dirt further into all those tight spaces. If you have a pressure regulator on your compressor, turn it down to like 30 or 40 psi. Just take the float bowls off and spray in the float bowl, in the float needle chamber, through your jets, and straight through the carbs.
also,,,before you re install the float bowls,,,,examine the float valve going up and down (while holding them bowl down),,,,being sure that it opens and closes the valve properly,,,,they may need a little adjusting (slight bend of the metal tang that makes contact with the needle valve).
They usually tend to be a bit out of adjustment on Raptors.
I had to adjust mine.
jrooker6
Apr 23, 2016 07:36 PM
Alex Rodak
Sep 12, 2015 09:39 AM
