Blaster handling?
Old Aug 12, 2000 | 01:35 AM
Mimcgl2's Avatar
Would wider tires and better tires, like holeshots or something, improve the blaster's handling and stability?
Old Aug 12, 2000 | 02:44 AM
volsblaster's Avatar
I put 20x11x9 Shredders on mine and they did improve the cornering a good bit. Shredders are very similar to Holeshots in the way they look just a little cheaper. If you choose the tire size I have then you will also need 1" offset wheels.
Old Aug 13, 2000 | 12:29 PM
20blaster00's Avatar
Volsblaster Don't you think your quad isn't running at its optimum performance. I have a 240 main in mine and i think i should be at a 250 and all i have is pro-circuit platinum and 304 silencer with airbox lid on. with a bored out engine you should almost deffenitely be higher. im no expert on jettin but if i was you i would go higher
dannytas
Sep 26, 2017 06:31 PM
badgerboy1
Sep 26, 2017 06:11 PM
Ahtatu
Sep 28, 2015 12:14 PM
Levi Enstad
Sep 26, 2015 08:00 AM
nastyblaster100
Sep 13, 2015 01:19 PM
