YFZ dune tires
YFZ dune tires
What dune tires would you all reccommend for the YFZ. I guess what I am mainly asking is what size of rims and tires would be best for climbing and speed/acceleration. I need to get some real soon as a few dune trips are coming up this summer. Thanks. Also, isn't it true that all yamaha sport quads have the same bolt pattern between all the quads.
YFZ dune tires
i dont know what will be best for your yfz but from what i understand the hauler paddle tires are the best for hill climbs.. and i dont know about hte other line up but the raptor and the shee are the same bolt pattern i dont know why they would change for the yfz.. if i were u i would get a 20 inch tire 8 paddle 10inch rim(because i personally like the look of a low profile tire..
YFZ dune tires
from my experience at Glamis all last winter.. the quickest tires for hill shooting and drags were
21-12 X8 haulers ( 8 paddle) with approximately 70" rollout
for general dunning the 20X11-10 or 20X11-9 in 8 paddle 63" runout work fantastic.. pump them up to 8 or 9 lbs and slide around turns like crazy
Skat doesn't make the 21x 8 paddle haulers anymore and and have been replaced by 22 x 8 paddle haulers ( I think they have the same runout as the 21 had??)
YFZ dune tires
Go with a 22 x 12 x 8 8 paddle hauler 8 wide rim .They set the tire so it has a nice round crown and allow it to grow at high speed which intern means less resistance on the sand .
Ive seen first hand how they work on Choke cherry hill on the Fofittys . if you run flat and wide paddles they dig big holes and you go no where fast . And dont worry about the Circumfrence the 450 handles it fine
