small banshee problem
Old Jul 19, 2004 | 10:58 PM
  #31
lapeerbanshee's Avatar
Default small banshee problem
oh ok thanks.
Old Jul 20, 2004 | 11:05 AM
  #32
iwantaTurbo's Avatar
not in the carb make sure you don't get it in the carb!!!!! just around it to see if you have any leaks going from the carb to the motor.
Old Jul 21, 2004 | 01:00 AM
  #33
superman187's Avatar
i was just kidding when i said it might be ready to blow up ...........
but seriously your carbs should not be open very far at all i mean like maby a 1/16 of an inch if that
if they are open 1/2 inch they are stuck open your slides only open about 1 1/2 inches wide open
my best guess it that your throttle is not releasing all the way
just
enough
to
have
fun
Old Jul 22, 2004 | 06:59 PM
  #34
how exactly does a killswitch hook onto a banshee in the catalog it says the key switch must be disconnected so where exactly does this hook to ??
Old Jul 22, 2004 | 07:57 PM
  #35
nighthawk68's Avatar
hey man. this happened to me on several occations. i dont know what caused it but it was an easy fix for me. all that happened to me was that the point at where the single cable splits into two, it was getting wedged where it goes into the splitter. causing the throtle to stay open. the point at which i am talking is located under the tank. make sure that the cables are in there perfectly. if not then it is acting like you have the throtel at about half open. i dont know exactly what caused it but my best guess whas that the cable is getting kinda old and the joints arent holding very tight anymore.
this may not be your problem but it is definatly worth checking.
Old Jul 22, 2004 | 09:19 PM
  #36
I rode it today and i popped it in second before the idling could get any higher then it went right back to normal but does anybody know anything else about the pro design killswitch??
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
cSchwartz
Jul 9, 2015 02:40 PM
Jul 7, 2015 11:00 PM
