small banshee problem
Old Jul 19, 2004 | 01:24 PM
lapeerbanshee's Avatar
Default small banshee problem
today i was going to ride my banshee and it was a real pain to start then i smelled gas so i know i flooded it then when i finally got it started it was idling really high could this be caused just from flooding it? i started it twice and it happened again i let it happen for about ten seconds then shut it off. so should i just ride it or is there a different problem?? thanks.
Old Jul 19, 2004 | 01:27 PM
silentdeath489's Avatar
That happened to me with my blaster, It turned out to just be the trottle cable was a bit loose. I was a pain to start then it idled extremely high. Just take a little look at the trottle cable and wiggle it.
Old Jul 19, 2004 | 01:32 PM
ok i'll check that out in a minute i just have to wiggle it?
Old Jul 19, 2004 | 01:55 PM
anybody else think they know what might have caused it??
Old Jul 19, 2004 | 02:22 PM
sAyIt_fmf's Avatar
Any time your have a throttle that revs out of control or high...it is usually a lean condition. This can be jetting (Which I doubt because you did not touch it).... OR carb boots that have popped off. (My first guess)....or a sticking slide or throttle cable.
Old Jul 19, 2004 | 02:24 PM
just check it see if it moves. Tell us what happens.
Old Jul 19, 2004 | 02:28 PM
dalegoldston's Avatar
Be sure to check your reeds.
Old Jul 19, 2004 | 03:50 PM
are you talking about where the cables go into the craburater or next to the hadlebars??
Old Jul 19, 2004 | 03:59 PM
KHolloman's Avatar
mine seems to rev high at times...all I do is hit the throttle one time and the idling goes down.
Old Jul 19, 2004 | 04:06 PM
ya mine usually does idle a little high when the engine is still cold but i was reving it for a little while then it started to scare me because i dont have a killswitch because mine was disconnected for some reason so i have to use the choke and shut off the gas and i didnt want it to start idling really high so i just shut it down.
