HELP with my 2001 Yamaha Warrior PLEASE
turning over means the engine is spinning [img]i/expressions/face-icon-small-tongue.gif[/img] fire means start. What you need to do is pull the plug out and put in a new one. Touch the threads of it to one of the engines fins and try to start the motor, the plug should start sparking. if it dosent then its either gaped horrible or there is something wrong electrically. If it does spark put it in and see if the bike runs. If it dosent pull it out and see if there is gas all over it. If there isint then start messing with the carb, if there is gas, and it does spark then check the compression.
