Metal in Oil Filter After First Change (Raptor 350)
Old 08-02-2004, 05:10 PM
static2229's Avatar
Default Metal in Oil Filter After First Change (Raptor 350)
2005 Raptor 350. I ran it past break in plus another 3-4 hours. I went to change the oil and found aluminum shavings in the filter. There were also metal shavings (i used a magnet). I was wondering if this is normal for the first oil change or if something may be wrong.
Old 08-02-2004, 05:14 PM
2000IAWarrior's Avatar
it seems to be normall for all warrior motors to have metal filings in the oil filter when u change the oil.. seems to happen all the time.. i had a lot of metal in my filter once.. but that was b/c the lower rod bearing went out.. but it does seem normail for these motors to have metal in hte filter
Old 08-02-2004, 05:16 PM
87warrrior's Avatar
i would call and ask the place where you bought it from to be sure...
04Raptor350Guy's Avatar
Thats cause it the first oil change since you broke it in. There should be less and less every time you do it.
Old 08-02-2004, 05:22 PM
NSA1499's Avatar
Exactly:
The more oil changes, the less metal. If not there might be an issue. For the first one it would be suspect if there was NO metal.
Old 08-02-2004, 05:59 PM
DarkManX's Avatar
well like in my recon they said its from striping gears (i striped them on purpose for wheelies) you might not be shifting correctly but if you know you are im not sure but my tip is call yamaha tell them the problem and they are gonna say "bring it in to us and let us look at it" tell them you wont have time your going on vacatin and whats the problem lol i hate dealers
Old 08-02-2004, 10:16 PM
clover's Avatar
Mine had the exact same thing after the first oil change.
Old 08-02-2004, 11:45 PM
DS650BajaRunner's Avatar
Part of breaking in process since the gears inside are running for the first time there are going to be some metal shards the firts few oil changes are going to have metal nothing to be concerned about its normal for all atv`s.
cody500ho
14
08-14-2015 05:03 PM
Dirtbikemike1
Technical and How-To Articles
10
07-12-2015 07:22 PM
Dirtbikemike1
07-11-2015 03:36 PM
Dirtbikemike1
07-09-2015 01:27 AM
yambam13
07-04-2015 01:49 PM
Quick Reply: Metal in Oil Filter After First Change (Raptor 350)
