Is there a way to make the stock throttle of the banshee less strong?
Old Aug 9, 2004 | 06:16 AM
ASDASD's Avatar
Default Is there a way to make the stock throttle of the banshee less strong?
Is there a way to make the throttle of the banshee less strong?
When you keep pressing the throttle for long times, your thumb starts becoming tired, so is there a way to make the throttle weaker so that you do not get tired as you are pushing the throttle.
Thanks.
Old Aug 9, 2004 | 08:58 AM
garyc660R's Avatar
Don't worry about it. After several rides it won't bother you.
Old Aug 9, 2004 | 09:50 AM
RAPTORAZ's Avatar
How about a twist throttle conversion?
Old Aug 9, 2004 | 09:56 AM
sAyIt_fmf's Avatar
Try rotating the whole thumb throttle assembly...it may be at the wrong angle for your sitting position. I actually moved mine up further than stock as I do a good bit of my riding standing up.
Old Aug 10, 2004 | 12:47 AM
FBOMBERS's Avatar
If you have the TORS eliminated you can take the spring outta the thumb throttle.You don't need it for anything but the TORS.The carb springs will do the job just fine.YOu should try 35 PWK's all day,those stockers ain't nothin'!
Old Aug 10, 2004 | 03:21 AM
ASDASD's Avatar
Dear FBOMBERS,
were is the TORS located exactly, what is it, how does it look like, and further how to take it out ?
I really appreciate your advise.
Thanks in advance.
Old Aug 11, 2004 | 12:04 PM
Shav0's Avatar
The TORS is a Throttle Override System that disables your throttle when it sticks wide open.
If you look on top of your carb, they are attached where the carb top goes. You can see the housing sticking out from the top of your carb. In order to remove them you will need a tors elimitor kit, that you can get from most places.
Check out http://www.vitosperformance.net/
Once you remove the TORS your thumb throttle will be alot easier to pull because its only pulling one direct cable to the carb as apposed to a linkage point inside the tors housing.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Ramman1
Jun 16, 2016 09:07 PM
Sjrpp
Jul 5, 2015 09:04 PM
