SCREW FELL INTO ENGINE!!!!!
Old Aug 17, 2004 | 08:51 PM
yamaharider200's Avatar
Default SCREW FELL INTO ENGINE!!!!!
Today I was working on my blaster. I had the reed cage out and one of the intake manifold bolts fell down into my motor. When it happened the piston was at the top of the cylinder so it didnt stop the bolt from falling down to the bottom of the cylinder and now i think its around the crank somewhere. It is caught in between something because i pushed down on the kickstarter lightly with my hand to see if the piston would still move and the piston went down and the halfway back up and then got stuck in the middle of the cylinder but i can still push the piston to the bottom of the cylinder with my hand. Do I have to take the whole egine apart to try to find the bolt or is there some easier way i can do it like using a magnet or something? any help is greatly appreciated.
Old Aug 17, 2004 | 10:07 PM
Hozed's Avatar
if its under the piston than you are probably going to need to take the top end apart atleast...
good luck man.
Old Aug 17, 2004 | 10:29 PM
raptorblasterracer's Avatar
thw entire top end needs to come off n then u might have to flip the motor upside down to get it out
a good days work for a normal personrmeber to torque the bolts down when rebuilding it
hey start thinking about a 240 since ur motor will be apart ne ways
slowgsxr97
Mar 18, 2022 03:40 AM
Aitch
Jul 21, 2015 09:40 PM
ghost civic
Jul 20, 2015 12:36 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
