yfz problems with the carb
Old Aug 24, 2004 | 10:58 PM
scumboy's Avatar
Default yfz problems with the carb
just wondering if any of u have stock yfz that may be jetted wrong or something . my buddys head pipe gets cherry red within a min or 2. i have takin it apart and cleaned twice and still red. this quads all stock . he removed and through away the baffle would that have any thing to do with it .
Old Aug 24, 2004 | 11:03 PM
limitdedsheerider's Avatar
taking off the baffle no that wouldnt have anything to do with it.
if you can take apart the engine and see if there are maybe scratch marks in the piston sleeve or anythign unusual(never know someone could have really messed up at the factory) just look for obvious things if that doesnt work take it to someone who knows what they are doing.
Old Aug 24, 2004 | 11:10 PM
Gills04yfz's Avatar
the header pipe glowing is normal they do run a lil lean from factory but the cherry red glow is normal for this bike
Old Aug 24, 2004 | 11:17 PM
Dynoray's Avatar
Hey Scumboy, Gills is right, they are a little lean from the factory and removing the baffle will lean it out even more. He will have to go up 3-4 sizes on the main and shim the needle (half clip) or move the clip down one full position. If he wants more power, tell him to remove the airbox lid, change the main to a 170 (if he is not to far above sea level) and raise the needle 1.5 -2 postions, retard the exhaust cam one tooth and put in a 2 deg advance key.
Makes 42rwhp on my Dyno from 36rwhp.
Dynoray
Old Aug 24, 2004 | 11:31 PM
scumboy's Avatar
dam u guy r quick , i just double checked and the pistons and sleeve r good to go. now that u hooked me up on a few sizes im back in the ball park . thanx
Old Aug 24, 2004 | 11:57 PM
RoostItUp's Avatar
Do searches please, there are many posts on this topic.
Old Aug 25, 2004 | 12:34 AM
Ernie660R's Avatar
45 pilot, 168 main should take of it.
Ty Speece
Jul 2, 2015 04:59 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
blaze_master
May 26, 2015 11:18 AM
