Wheel Spacers
Old Aug 31, 2004 | 02:24 PM
Shav0's Avatar
Default Wheel Spacers
Girlygirl. If your buying new a-arms, you can get away with using the stock shocks. They only way you will need new shocks is if you buy long travel arms.
The durablue ones come in a set. They widen the front 1.5 on each side and the back 2.5 on each side. I use them and have no problems. You can even jump with them on, as long as your not having hard landings or caseing alot.
Dfitz's Avatar
I have not used them on the back but I think they will work. I purchased mine on eBay if you search raptor wheel spacers. I have purchased all mine from mudusaracing 3" black powder coated.
Old Aug 31, 2004 | 04:39 PM
BURKEDADDY's Avatar
sand sport are way to expinsive i would recomend the dmi wheel spacers ive got some on the front just got some for the back and was going to put them on the other day untill my axle nut problem happened but check ebay i got my front wheel spacers for 41 dollars and the the rear for 67 dollars from the dmi auctions
Old Aug 31, 2004 | 05:21 PM
elraptor02's Avatar
i want them
Old Aug 31, 2004 | 05:26 PM
  #15
scrambler123's Avatar
I used the bolt extender style on my old blaster and they never have me any problems.
Old Feb 27, 2005 | 08:41 PM
  #16
Boosh71's Avatar
Has anyone tried the type of wheel spacers that have the holes for the stock bolts, and then another set of bolts for the wheels? The kinda I tried are like that, but when I try to tighten them then bolts in the spacers tend to spin with it... I can't tighten them unless I hold the bolt on the other side, which is impossible because of the wheel and the brake rotor...
badgerboy1
Sep 26, 2017 06:11 PM
Oct 10, 2015 10:20 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
tysonbully
Sep 28, 2015 02:30 AM
r1pilot83
Sep 27, 2015 07:38 PM
