project suspension, need help !!!
Old Aug 31, 2004 | 08:21 PM
bvwarrior's Avatar
Default project suspension, need help !!!
I can get banshee a-arms, the 3 shocks, tie rods , and axle for preety cheap, but i was wondering is there a way I can get the a-arms to fit my warrior, because the banshee's are different, and are they longer, and would it make a big difference, also for the axle, will it fit, if i have to change the bearings thats not a problem, do the sprocket hub and brake hub fit the banshee axle ? thanks any response will help out !!
Old Aug 31, 2004 | 08:32 PM
bvwarrior's Avatar
come on guys / gals anything would help !!
Old Aug 31, 2004 | 08:39 PM
bvwarrior's Avatar
i know the banshee's top a-arms have a straight bar goin across the top, and the warrior doesn't but i was thinking i can just cut off the bar or cut off the metal bracket and reinforce the other one so it might work ??
Old Aug 31, 2004 | 08:43 PM
RoostItUp's Avatar
The A-arms wont work at all and moding them would be risky and possibly very unreliable which could cause an injury.
The axle looks like it would but you'd have to try it to know forsure
The 3 shocks will but I would keep the Warrior ones
And if you need new tie rods just buy better ones, the Shee ones arn't any better than the Warrior ones.
Old Aug 31, 2004 | 08:45 PM
bvwarrior's Avatar
thanks, but i think i'm still gona check it out, because i'm preety sure i can get them to fit, but i could be wrong! but i'm also gona check to see if it will make me widder or not, if not then i'm not gona do it
Old Aug 31, 2004 | 08:50 PM
warrior68man's Avatar
The rear shock wont fit without modding the air box The piggback resivoir hits it.
Old Aug 31, 2004 | 08:54 PM
bvwarrior's Avatar
thanks
RoostItUp's Avatar
I really wouldn't trust that upper a-arm modded, if you cut it and fit it on it's just gonna end up bending. It's made to be attached to one big bushing, if you change that the steel design is gonna put pressure on points that wern't originally designed for it which will cause it to fail. Good luck though and don't hurt yourself!
Old Aug 31, 2004 | 08:57 PM
bvwarrior's Avatar
i won't get hurt '' i hope '' , and i was gona reinforce the frame, but i'm not sure this stuff will give me what i want, so i'm gona talk to the guy tomorrow and see if i can take some mesurements
Old Sep 1, 2004 | 12:17 AM
dredog's Avatar
you are crazy if you try to modify them to fit. fitting is one thing the geometry on the frames are very different and the shocks for a banshee have different spring rates cause the warrior is much heavier.
Specta
Family ATVing Photos
Dec 7, 2018 08:22 PM
Robinhood
Dec 26, 2015 10:28 AM
mywifesquad
8
Sep 21, 2015 08:20 AM
bigred20653
Sep 19, 2015 02:11 PM
chewy78
Sep 8, 2015 10:37 AM
