2004 grizz Clutch
Old Sep 6, 2004 | 06:03 PM
MNFastBoat's Avatar
Default 2004 grizz Clutch
two weeks ago I sunk mine bad [img]i/expressions/face-icon-small-sad.gif[/img]
put it all back together today after cleaning the carb out, changing all oil and diff fluids. Pulled the belt housing off to clean out also.
Started fine, ran fine above idle at stand still
took it for a spin down the block and could not get above 27mph [img]i/expressions/face-icon-small-sad.gif[/img]
is this because the belt housing was off?
I could not see the clutch move in or out at all.
Even revs seemed real high
Put it in low and was revving higher [img]i/expressions/face-icon-small-sad.gif[/img]
Does this clutch need to be re greased?
Shaft stuck?
HELP [img]i/expressions/face-icon-small-sad.gif[/img]
Or should I just take it in and hope warranty will cover it?
Old Sep 7, 2004 | 04:55 AM
MNFastBoat's Avatar
TTT
Old Sep 7, 2004 | 12:46 PM
hondabuster's Avatar
Im not sure it would be covered under warentee. Once they get the cover off, theyll know it was in deep water. Did you find anything inside, besides water? Dirt, muck? Is it totally dried out?
Old Sep 7, 2004 | 01:13 PM
MNFastBoat's Avatar
thats what I thought also [img]i/expressions/face-icon-small-sad.gif[/img]
it is NOW dried out
blew everything out with compressed air
I just was not sure what needed to be greased.
never had one apart before so looking for input before tearing it apart
Minimod
Sep 10, 2015 08:03 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
quickwhips
Sep 2, 2015 06:53 AM
cdstang
Aug 31, 2015 07:52 AM
