Blaster - Exaust Trouble
Old Aug 23, 2000 | 01:08 AM
MikeyM's Avatar
I've got a '94 blaster and I just did a major rebuild. I also removed the oil injection and started mixing which I've done 32:1. I noticed that my pipe is blowing white smoke pretty much the whole time it is running and I noticed a black oily substance leaking from the pipe. Is this normal, if not what should I do. I've got a reed spacer and boyeson reeds and the engine has been bored once over. Thanks
Old Aug 23, 2000 | 12:29 PM
sAyIt_fmf's Avatar
What kind of jetting are you running? And what color are the plugs?
White smoke usually means lean somewhere along the line.
But the situation you descsibe almost sounds like it is rich.(with oil dripping from the pipe)
Old Aug 23, 2000 | 08:39 PM
20blaster00's Avatar
white smoke or is it bluish tint. if its blue its fine. and as long as that substance isnt coming out at an alarming rate then your fine
Old Aug 23, 2000 | 11:32 PM
brokemybanshee's Avatar
nothin wrong with a little blue smoke :-)
Old Sep 5, 2000 | 06:35 PM
01blaster's Avatar
i have a 2001 blaster and i have the same problem but from what yall said i guess i shouldnt worry. MikeM where at in Nederland do you live i live in nederland maybe we could ride i have some friends that will go
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
Clint Russell
Sep 25, 2015 03:20 PM
nastyblaster100
Sep 13, 2015 01:19 PM
