Clutch Troubles
Old Sep 9, 2004 | 10:20 PM
silentdeath489's Avatar
Default Clutch Troubles
Well when i was riding i realized i was stalling after i stoped. Then when I was going to start it in gear I would hold the clutch down and kick it, but when i did i moved a little like i wasn't holding the clutch. I have the 2mm gap or whatever it's supposed to be. What should i do? Should i tighTIN the clutch? Is that safe or will it wear? Also the needle in the carb is sticking what should i do?
Old Sep 9, 2004 | 11:23 PM
bvwarrior's Avatar
clean out the carb , check to see if the needle is straight, then adjust the clutch if it is sliping it is probably finished !!
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
tysonbully
Sep 28, 2015 02:30 AM
Clint Russell
Sep 25, 2015 03:20 PM
jbrewster94
Sep 23, 2015 04:16 PM
